Mapbook used to have an option to "Select tile when drawing" option on the Map Sheet Wizard. This allowed the selected item to be highlighted blue when chosen. In DDP I can get the active item to select and the map portion of the map series will generate fine but the record is not "selected"in the sense of highlighted in blue. I use autoreated and a related table to chart data from multiple records that are related to the original seleted (chosen) active item. Since the charts are based upon "Show only selected features/records on the graph" and there is no "selected" record in the original file, the charting does not change from map to map. Is there a way to select the active item and highlight the active item?
