Adjust color ramp raster tif
8256
14
05-08-2017 03:51 AM
AnneTrampe
Hello everyone,
I am trying to reproduce the same characteristics of a raster tif than the same attached in the picture.
I have a raster tif with different value. I already excluded all values above 1000 as they are land area.
I now want to have a descrete color ramp or stretched color ramp, but want to adjust it with certain values/breaks where the colour changes. it should look like this:
But I just achieved this:
PanGIS
Start from the bottom.
Probably it's because the values overlap.
PanGIS
Hi, not sure if it is what you need but you can give it a try:
change the stretch type into Min-Max
then check Edit High/Low value and change the values.
AnneTrampe
Now, I can set them manually, but I can not change the values in between. What I mean is: I want also a legend like above, showing the value steps between min and max with the values and like to adjust them manually so from 0.1-1, 1-10, 10-50, 50-100, 100-300 and 300-1000, but still as stretched color. Now it looks like this:
PanGIS
Click on Labeling button and see change the values from there.
AbdullahAnter
Honored Contributor
I think there is same answered question , see this link Assigning static colors to specific values on a stretched color ramp
AnneTrampe
Okay, I did the labelling. Changed number of intervals and as I don't want the same intervalls I tried to change the values manually, but didn' work. I type in the right value, but it switches back to the original value.
PanGIS
Not sure why, but it does the same to me.
Do this:
1) labeling: change the values as you like
2) click OK to close the window (apparently I have to click twice)
3) straight after click Apply in the Symbology tab
4) reopen the Labeling and now it should be changed and the symbology reclassified.
AnneTrampe
Okay, now I can change the label, but still not the values. So in the end it is still wrong as I need to change the values that are in that class/range
AnneTrampe
Value and Label should be the same
PanGIS
Change the values, not the labels.
If you change the values, the labels change accordingly.
(Sorry, just realized that before I wrote "labels" instead of values.)
