Enterprise Geodatabase in Oracle CDB & PDB - Best Practices and Recommendations
1331
12-12-2024 02:00 PM
MarceloMarques
📕 Documentation:
Geodatabases in Oracle—ArcGIS Pro | Documentation
Connect to Oracle from ArcGIS—ArcGIS Pro | Documentation
Multiple Geodatabases in Oracle—ArcGIS Pro | Documentation
🔍 Question:
Is it possible to use Oracle 19c container database (CDB) with PDB (Pluggable Database) to manage the different production geodatabase in multi user & multi geodatabase version production environments? Does Esri recommended to use it?
🌍 Marcelo's Answer:
Yes, it is recommended to use Oracle Pluggable Databases to store the Oracle ArcSDE Geodatabase.
To enhance the process of consolidation, it is highly recommended to adopt the advanced capabilities offered by the Oracle 19c multi-tenant architecture. In this framework, the container database, commonly referred to as CDB, will serve as the central host for multiple pluggable databases, known as PDBs. Each of these pluggable databases operates independently, functioning as a standalone geodatabase that comes equipped with the necessary ArcSDE repository installed for optimal performance and management of spatial data. Furthermore, it is advisable to discontinue the use of Esri user-schema geodatabases, as shifting to this new architecture promises more efficient data management and scalability options.
🎯 ArcSDE User-Schema Geodatabases in Oracle are deprecated
🔍 Question:
 We
 created the database in Oracle 19c as a single geodatabase with multiple Data owners at department level. However, In the Production Mapping best practices ESRI recommended to create separate geodatabases for each cartographic scale e.g. pm25 (1:25K), pm50 etc. and best practices recommend to create an Oracle Container Database (CDB) with Oracle Pluggable Databases (PDBs) to ensure scalability and compliance with ESRI standards. This issue raises concerns about the long-term viability of the current database structure. We would like your feedback on whether our current Oracle geodatabase structure is compatible with ESRI Foundation Production Platform project.
🌍 Marcelo's Answer:
  • Maintaining a single geodatabase with multiple data owner users is NOT an effective setup for Enterprise Geodatabases for a large national mapping organization when there are multiple data models and large datasets like Topographic Mapping and Maritime ENC
  • This configuration can lead to serious limitations, create bottlenecks for scaling the geodatabase, and result in performance issues
    • It will make difficult to orchestrated and operate data workflows to edit and update the data
    • Particularly when working with geodatabase versioning (whether traditional versioning or branch versioning).
    • Different data models have varying requirements for geodatabase versioning strategies. Therefore, it is essential to store these distinct data models, such as Topographic Mapping MGCP, TDS, Maritime Charting ENC, and Maritime Bathymetric, in separate geodatabases.
    • It can complicate database maintenance tasks such as rebuilding indexes and gathering new statistics.
    • It can lead to serious database lock issues and make schema changes difficult to perform, for example to add a new field.
  • To avoid these issues, it is best practice to transition to an Oracle Container Database and utilize Pluggable Databases (PDBs).
  • Each PDB should serve as a separate geodatabase tailored to specific data models and data separation needs.
  • If using different ArcGIS products, such as Data Reviewer and Workflow Manager, each of these applications should also have its own dedicated geodatabase.
  • Furthermore, data can be separated by cartographic scale, and each scale can be stored as a separate geodatabase.
🌏 Marcelo's remarks
  • Oracle/Geodatabase Administrators greatly benefits from taking the time to review the Database Guide Books for Production Mapping (Topographic Mapping) and Maritime Mapping, among the others available in my community.esri.com blog.
    community.esri.com - Mapping and Charting Solutions (MCS) Enterprise Databases Best Practices
  • These guidebooks serve as a valuable resource, providing essential knowledge and best practices that can serve as a strong foundation for the production physical database setup work.
  • Oracle/Geodatabase Administrators also need to read and understand the Database Connections Best Practices. This is very important to avoid future issues with database deadlocks.
  • To further enhance the physical database and geodatabase setup efforts, the Oracle/Geodatabase Administrator has the ability to access my Oracle Database Template Scripts also available for download at my community.esri.com blog.
    • the scripts cover the guide books best practices
    •  the scripts also have very advanced rdbms and advanced geodatabase best practices that go beyond the database guide books recommendations
  • The Oracle Database Template Scripts are designed to facilitate and streamline the process of designing and setting up the physical Oracle geodatabases, making it easier to align with project goals and requirements.
  • By utilizing these templates, the Oracle/Geodatabase Administrator can reduce the complexity of database design and setup and ensure that it meets industry standards and meets the geodatabase best practices for performance, scalability and maintenance.
  • I recognize that navigating these materials and processes can sometimes feel overwhelming for our customers. It's completely understandable, given the technical nature of the work.
  • Customers can engage with Esri Professional Services to request consulting hours and request my assistance if they need.
  • By collaborating closely with the customer, I can help design, setup and configure the Oracle geodatabases effectively.
  • This hands-on support not only makes the process more manageable but also empowers the customer by ensuring they have a robust and functional database system tailored to their needs.
I hope this provides clarity on the question. If there are any additional inquiries or if further discussion is needed, I am more than happy to ensure all concerns are addressed. You can send me a private message in the community.esri.com if you wish to discuss anything further.  (1) Private Messages - Esri Community
Thanks,   🙂   👍
| Marcelo Marques | Esri Professional Services ArcGIS Products | Principal Product Engineer |
| Cloud & Database Administrator | OCP – Oracle Database Certified Professional |
| Esri | 380 New York St | Redlands, CA 92373 | USA |
| T +909-369-1787 | M +909-255-2079 | [email protected] | esri.com |
| Esri Enterprise Mapping and Charting Databases Best Practices |
| https://www.linkedin.com/in/mmarquesbr/ |
"In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 32 years, my passion for GIS has only grown stronger."
THE SCIENCE OF WHERE ®
Contributors
About the Author
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | 33 years' experience | www.linkedin.com/in/mmarquesbr | | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career." | | " a successful Enterprise ArcGIS application deployment starts with a strong physical database design and best database administration practices" | | “The mountains are calling and I must go.” – John Muir | | " I do not fear computers. I fear the lack of them." - Isaac Asimov |
