Search result pop-up window: fields do not follow pop-up configuration and show in alphabet order - Local map V3.1
507
02-20-2025 04:34 PM
Labels (2)
AnhDang
Kia ora,
I am trying to configure the search result pop-up window, but it does not follow the intended configuration. I am encountering two issues:
  1. All fields appear in the pop-ups – Despite removing many fields in the pop-up configuration, they still appear in the search result pop-up window. I tried hiding fields in the attribute table, which worked, but this requires a separate service for search, in addition to the map layer service. What we want is for users to still see all fields when they open the layer's attribute table.
  2. Field order issue – The fields appear in alphabetical order, but we want the main fields to be displayed first. I tried adding number to the field aliases, but it did not work. Please see the screenshots below for reference.
Could you please provide advice on how to resolve these issues?
Many thanks,
AD
Alphabetical order
Test to add number but it does not work
Aravindh_Rajendran
Hi @AnhDang , We may need more information to understand these issues more and then can work with you to resolve this. Could you please log this as a case with our Support team through gissupport@eagle.co.nz
Aravindh
AnhDang
Hi @Aravindh_Rajendran: Many thanks for considering my question. Yes, I will log a case to Eagle Support Team. But I would like to give you more detail using Eagle Local Map testing site Eagleton City Council
For example,
- Go to the "Walks and Trails - Demo" map,
- Search for "The Whale Trail"
- In Search, click on "The Whale Trail" under "Walks and Trails"
- The search result pop-up is opened, and the fields in the pop-up follow alphabet order
Can you please test whether you can configure the order of fields (using a preferred order) and hide some fields in the search result pop-up?
Many thanks,
AD
