LocalMaps NZ Questions
Latest Activity
Sort/Filter :
POST
Kia ora all,We have recently identified several cases where the Search widget does not always return the expected res...
Aravindh_Rajendran
by Aravindh_Rajendran Esri Contributor Esri Contributor
in LocalMaps NZ Questions Last Updated 03-05-2026
1 1
POST
I created a customised popup with a title and text for that layer In MapViewer and that works well when you click on ...
Marie-LouLabuschagne
by Marie-LouLabuschagne Occasional Contributor
in LocalMaps NZ Questions Last Updated 12-01-2025
3 2
POST
I created a Search on a Property layer.  The Search function works well, but the polygon is selected in orange. I cha...
2 3
POST
Kia ora,I am trying to configure the search result pop-up window, but it does not follow the intended configuration. ...
AnhDang
by AnhDang Emerging Contributor
in LocalMaps NZ Questions Last Updated 02-27-2025
1 2
POST
POST
Hello,When I select multiple objects (e.g. land parcels) in LocalMaps, it’s unclear which record in the attribute tab...
SouthWaikatoDistrictCouncil
by SouthWaikatoDistrictCouncil New Contributor
in LocalMaps NZ Questions Last Updated 08-01-2024
0 1
POST
Hello, I encountered an issue in LocalMaps 2.3 where selections made with the Select Tool do not appear in the saved ...
0 1
POST
Hello, I would like to know whether the Swipe Widget, which allows people to compare layers and aerial images, is ava...
LynnNi1
by LynnNi1 New Contributor
in LocalMaps NZ Questions Last Updated 07-22-2024
1 1
POST
Hi, our users have noted that the measurement text can be difficult to read against certain backgrounds, as there is ...
LynnNi1
in LocalMaps NZ Questions Last Updated 07-03-2024
1 1
POST
I’ve just been made aware of this article and the upcoming change to the Chromium engine in July which affects Enterp...
GISOfficer
by GISOfficer Frequent Contributor
in LocalMaps NZ Questions Last Updated 06-24-2024
0 4
POST
Hi does anybody have anything set up to allow the LocalMaps popup to have a link that opens a file on a local server?...
MonikaNicholsRDC
by MonikaNicholsRDC Occasional Contributor
in LocalMaps NZ Questions Last Updated 10-12-2023
0 4
POST
In LocalMaps 2.3 it is not possible to rotate a symbol such as an arrow that is chosen from the point symbols library...
GISOfficer
in LocalMaps NZ Questions Last Updated 05-29-2023
2 1
POST
Hey Localmaps team!We use Localmaps for LIM reporting and are looking at rolling out a few more different types of re...
TerryOD
by TerryOD Regular Contributor
in LocalMaps NZ Questions Last Updated 05-28-2023
0 2
POST
I have had a user request to be able to zoom to a specified scale in the LocalMaps viewer e.g. 1:50,000. I haven't fo...
MonikaNicholsRDC
in LocalMaps NZ Questions Last Updated 05-24-2023
1 2
POST
Have published print service with new templates, I know its active. Toggled layout options in the localmaps admin too...
GIS_AdminHorizons
by GIS_AdminHorizons Emerging Contributor
in LocalMaps NZ Questions Last Updated 04-05-2023
1 1
64 Subscribers
