WebTiledLayer tile loading indication
2286
02-10-2024 08:47 AM
dev4567
Is there a way to indicate concrete tile is being loaded? Some tiles could be quite massive and users with poort network connection should know the tile is actually loaded and not just empty or "stuck"
Tags (1)
PuneetPrakash
You can set how a tile request that returns 'No Data' is resampled by setting noDataTileBehavior  property on the WebTiledLayer,
This lets you choose what to display where the tile should have been displayed,
NoDataTileBehavior.UpSample - Resample the pixels from a lower level of detail tile.
NoDataTileBehavior.Blank - The 'NoData' pixels will show the raster picture as being blank (or disappearing).
NoDataTileBehavior.Show - This will show the raster picture with the text 'No Data' stamped over it once you pass the lowest level-of-detail scale.
https://developers.arcgis.com/kotlin/api-reference/arcgis-maps-kotlin/com.arcgismaps.mapping.layers/...
dev4567
unfortunately, this doesn't help when the map is being loaded the first time
PuneetPrakash
You can try using the layerViewStateChanged  callback on the GeoView that gives you the LayerViewStatus on individual layers in the MapView. When the tiles in the WebTiledLayer are not successfully loaded you will get the Warning LayerViewStatus. If you get that then the LayerViewState.error property will provide more details about the specific problem which was encountered.
dev4567
This is inaccessible in compose toolkit -> please, add same the shared flow functionality to the `GeoViewProxy` – currently there is only `getLayerViewState` which is not that convenient to use
dev4567
@PuneetPrakash please, consider proxying the same functionality to the compose toolkit's `GeoViewProxy`
