POST | Hi community After updating to the latest version of the ArcGIS Maps SDK, we started experiencing a runtime error wh... by NicoleLeiva25 New Contributor 4 1 | 4 | 1 | 153 | |
POST | I'm displaying a CustomTiledLayer. When the internet connection is poor, some map tiles fail to load, and blurred til... by mobileuser Occasional Contributor 1 0 | 1 | 0 | 107 | |
POST | We use LocationDisplayAutoPanMode.Navigation while we show navigation directions to a destination and it works fine.O... by GabrielDogaru New Contributor 0 0 | 0 | 0 | 106 | |
POST | I've been following instructions here: https://developers.arcgis.com/documentation/security-and-authentication/app-au... by johnms93 Emerging Contributor 0 0 | 0 | 0 | 130 | |
POST | I want all ArcGIS Kotlin SDK traffic to go through a proxy. I would expect to set this through the HTTP client, but t... by johnms93 Emerging Contributor 0 3 | 0 | 3 | 296 | |
POST | On the MapView there is the setViewPointRotation function. This function animates the rotation of the viewpoint. Is t... by mobileuser Occasional Contributor 0 1 | 0 | 1 | 227 | |
POST | I have a requirement to signal off the screen markers by showing some icons at the edge of the screen, in the directi... by GabrielDogaru New Contributor 0 1 | 0 | 1 | 249 | |
POST | Compose MapViewProxy lacks a bunch of APIs already accessible from the underlying MapView / GeoView e.g.: getCurrentV... by dev4567 Emerging Contributor 0 2 | 0 | 2 | 271 | |
POST | Hi There,I am using Compose maps SDK ("com.esri:arcgis-maps-kotlin-toolkit-bom:200.6.0")As shown in above screenshot ... by PrashantGaykar Occasional Contributor 0 5 | 0 | 5 | 492 | |
POST | Hello!We are using version 200.6.0 of the SDK and have noticed an issue where the location position pointer is unstab... by NicoleLeiva Occasional Contributor 3 2 | 3 | 2 | 443 | |
POST | `StrictMode` policy indicates that `LocationDisplay` loads a bitmap in the Main thread and it's slow:`android.os.stri... by dev4567 Emerging Contributor 0 1 | 0 | 1 | 362 | |
POST | Hello everyone,We’ve been encountering recurring app crashes reported by our monitoring tool. These crashes seem to s... by NicoleLeiva Occasional Contributor 5 2 | 5 | 2 | 440 | |
POST | For example, with the old SDK (100) I had a few actions on the double tap. In one case, I do something and return tru... by JR1S New Contributor 0 0 | 0 | 0 | 288 | |
POST | I have username and password from portal (ArcGIS Enterprise 11.2). How can I get a LicenseInfo from that to set for ... by SonMinh Emerging Contributor 0 5 | 0 | 5 | 629 | |
POST | What are the exact curve values of the AnimationCurve objects? We want our compose animation to match the viewpoint a... by dev4567 Emerging Contributor 0 4 | 0 | 4 | 447 |
User | Count |
3 | |
2 | |
2 | |
2 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 |
