Map Server Layer pulled from URL with invalid security certificate
1924
07-21-2023 12:52 PM
klebercj
I'm attempting to narrow down issues I'm having pulling a map server layer into my Android project.
I'm trying to pull in a map layer from a dev server and place it on top of an ESRI basemap layer.  So far I have had no luck with pulling in the map server layer.  The URL for the layer (without identifiable information) is https://xxxxx-dev.xxxxxxx.net:6400/arcgis/rest/services/..../MapServer.
I do know these things;
1) My code will pull in an ESRI public map server layer and place it over a base map layer.
2) The URL for the map server I want to pull from makes me "Accept the Risk and Continue" when I look at it through a web browser.  The URL uses an invalid security certificate.
3) I don't have the authority to change or update that certificate.  This layer is just for dev work though and will not be used in the final product.
I don't know these things;
1) Is the invalid security certificate causing the layer to not render?
2) Is there a way to configure network setting inside the app so that I can continue with development?
3) Am I barking up the wrong tree on this?
Any help would be appreciated
klebercj
Appreciate the response.  I'll take a look at this see what I can do.
klebercj
Additional info is that this map server I trying to pull from is an ArcGIS server configured with a self-signed certificate.  It's communicating through the default 6443 port.
klebercj
Anyone have an opinion or idea regarding this?
Erick_1
Hello @klebercj ,
It seems that the dev server you are trying to use is self-signed and the connection is being refused.
You have a couple options:
1. Install the root certificate in your device so that the device automatically trusts the dev server you are trying to access.
   - To verify that this was done correctly, try going to the dev server using your mobile browser and you won't get the ""Accept the Risk and Continue" message anymore.
2. Create a NetworkAuthenticationChallengeHandler that returns a ServerTrust network credential when the NetworkAuthenticationType is of type ServerTrust.
  - Warnign: This will trust all self-signed server certificates and should only be used in test environments and NOT for production.
override suspend fun handleNetworkAuthenticationChallenge(challenge: NetworkAuthenticationChallenge): NetworkAuthenticationChallengeResponse {
        return when (challenge.networkAuthenticationType) {
            is NetworkAuthenticationType.ServerTrust ->
                NetworkAuthenticationChallengeResponse.ContinueWithCredential(ServerTrust)
klebercj
