Python parameter type changed during packaging from python to geoprocessing package
3643
04-15-2013 01:57 PM
by Anonymous User
Not applicable
Original User: dwong@lgc.com
I try to set up a geoprocessing service from a very simple python script.  The parameters are:
�?� Input Features
    o Data Type: FeatureSet
    o Type: Required
    o Direction: Input
�?� Output File
    o Data Type: File
    o Type: Required
    o Direction: Output
It looks fine in ArcMap during its packaging into gpk:
[ATTACH=CONFIG]23530[/ATTACH]
It does not look fine when I use the sample Runtime app com.esri.client.samples.geoprocessing.LocalGPTaskInfoApp to look at the parameters:
[ATTACH=CONFIG]23531[/ATTACH]
The inFeatureSet switch from the Feature Set type into the GPString type.  Subsequently, the geoprocessing operation fails with the following error that appears to be related to the parameter type:
[ATTACH=CONFIG]23532[/ATTACH]
Not sure how the parameter type gets changed in the gpk.
Need some pointers to keep the parameter type from changing.
Thanks.
by Anonymous User
Not applicable
Original User: gyoung76
Here's what I discovered:
  • if you use either of the following forms of python code, the parameter becomes a GPString (verified by using the LocalGPTaskInfoApp sample)
  • [INDENT]InputGPFeatureRecordSetLayerPoints = "InputGPFeatureRecordSetLayerPoints [150757_04232013]"
    [/INDENT]
    [INDENT]InputGPFeatureRecordSetLayerPoints = "in_memory\\{1ECB4347-E633-41A8-9809-F3CE032625D3}"[/INDENT]
  • if you use the following form, the parameter becomes a com.esri.core.tasks.ags.geoprocessing.GPFeatureRecordSetLayer. This is the type that corresponds to FeatureSet.
  • [INDENT]InputGPFeatureRecordSetLayerPoints = "%ScratchWorkspace%\\scratch.gdb\\InputGPFeatureRecordSetLayerPoints"
    [/INDENT]
I'm not sure where or how you see the dialog that shows you the parameters are good while creating the GPK, I think you must have 10.1 SP2; so I'll give that a try. The "Working with feature sets and record sets" may give you other ideas of how to force a feature set in python.  http://resources.arcgis.com/en/help/main/10.1/index.html#//002z0000001n000000
Gayle.
RavindraSingh
I to have similar issue.
When I pass the input Parameters:
and say:
geoprocessor.executeAsync(parameters, new CallbackListener<GPParameter[]>(){
@Override
public void onError(Throwable e) {
e.printStackTrace();
return;
@Override
public void onCallback(GPParameter[] result) {
if(result != null){
System.out.println("success");
It gives following error::
com.esri.core.io.EsriServiceException: Unable to complete operation.
Error executing tool.: ERROR 000735: inGraphics: Value is required
at com.esri.core.io.EsriServiceException.fromJson(Unknown Source)
at com.esri.core.internal.io.handler.c.a(Unknown Source)
at com.esri.core.internal.io.handler.l.a(Unknown Source)
at com.esri.core.tasks.ags.geoprocessing.b.b(Unknown Source)
at com.esri.core.tasks.ags.geoprocessing.b.a(Unknown Source)
at com.esri.core.tasks.ags.geoprocessing.b.execute(Unknown Source)
at com.esri.core.internal.tasks.b.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
