Labels not visible in Sample Symbol Dictionary in 10.1.1
8293
11
02-05-2013 10:30 PM
MarcoHüther
The labels in the SymbolDictonaryApp sample are only visible for a few symbols. For Air Tracks for example no labes are visible. In version 1.0 it works. Here is a screenshot:
[ATTACH=CONFIG]21488[/ATTACH]
MarkBaird
Hi
I'm assuming you are using 2525c symbology here.
We recently identified an issue with the UniqueDesignation section of the message which is typically used for adding labels to 2525C symbols.  The problem is a case issue, so if you use "uniquedesignation" in your message instead it should work.
Does this help?
Mark
MarcoHüther
The problem still exists but only for a few symbols. Ground Tracks for example have an label, but Air Tracks not.
MarkBaird
I can see this too.  I'll talk to the symbol dictionary team and report back...
Mark
CarlosColón-Maldonado
Was this resolved in 10.2?
Will this be resolved in 10.2.3?
ChristopherMoore
Unfortunately, setting the properties to get the correct labels to show up using the MessageProcessor has been somewhat of a point of confusion, the Github repo that hosts this data attempts to clarify this here:
https://github.com/Esri/military-features-data/tree/master/data/mil2525c#modifier-label-fields
But I believe those properties names listed there have only been tested using the latest version so hopefully these will also match your version of the software. I *think* the only thing that changed from version to version was in older versions Case/Capitalization was not significant and in the newer versions the casing of the properties do matter. Hope it helps.
- Chris
You aren't kidding!
... the Github repo that hosts this data attempts to clarify this
Where have you been for the last 10 months?;)
Thanks for the link.
I believe you have correct thinking. I'll give these instructions, and those on the link, a try and see what happens. Yes, this certainly helps. I appreciate your response.
I'd like to report that the unpublicized properties listed in the aforementioned link completed most of my requirements, except one. The "datetimevalid" property seems to add a "/,", along with new line character to the displaying label. When I call 'this.setProperty("datetimevalid", timeFunction);' where 'timeFunction' equates to "172025ZAPR2014", I get the display below. Is there a workaround to this?
After further testing, I learned that the "higherformation" property label behaves similarly to that of "datetimevalid" property label, except it doesn't include the comma after the forward slash. I've also tried all of the related properties pertaining to tactical graphics ("additionalinfo2", "uniquedesignation2", "zmax" and "zmin") on symbol codes of dimension type "Tactical Graphics", and none of them displayed any labels.
