graphic selected
2394
06-03-2014 06:38 AM
AhmedAlqusaibi
I used the sample code for selected graph
ArrayList idList = new ArrayList();
public void featureHit(com.esri.toolkit.overlays.HitTestEvent event) {
      // get hit graphics
 List<Feature> hitGraphics = event.getOverlay().getHitFeatures();
      myGraphicsLayer = (GraphicsLayer) event.getOverlay().getLayer();
      for (Feature graphic : hitGraphics) {
        id = (int) graphic.getId();
        if (myGraphicsLayer.isGraphicSelected(id)) {
          // if graphic is selected in the layer, unselect it
          myGraphicsLayer.unselect(id);
          } else {
          // otherwise select graphic in the layer
          myGraphicsLayer.select(id);
          idList.add(id);
So, I'm recording all the ID's for the graph in arraylist and I've action button connected Action Listener which perform this code
for(int i=0;i<=idList.size();i++)
                        System.out.print(id);
The problem is, it's only unselected the last ID graph, the others unaffected. So what do you suggest? I'm using 10.2.3
EliseAcheson1
If that's the exact code you're using then (in second code snippet) I don't see where you are using the 'i' from your for loop?
Also note that GraphicsLayer has methods to deselect all selected graphics in the layer (clearSelection()) and to get the IDs of all selected graphics (getSelectionIDs()), so those might be handy depending on what you're doing.
~elise
