Using Style files in ArcGIS Runtime SDK for Java
2236
05-25-2014 04:56 PM
NogyAugustine
Hi
I'm new to ArcGIS Runtime SDK for Java, would like to know whether we can use a style file for setting the symbology in a graphics layer.
Thanks in advance.
Regards,
Nogy
MarkBaird
Hi Nogy,
We set the symbology of graphics in a graphics layers per graphic as in this article:
https://developers.arcgis.com/java/guide/add-graphics-and-text.htm
I do want to double check that you are using the Runtime API and not the JavaScript API as you are talking about style files.  My answer assumes you are a Runtime developer.  If that's not right I can point you in the right direction.
Mark
