Upload local Image file to ArcGIS Image for AGOL using API
4281
13
02-18-2022 12:57 PM
MichaelWen
Is there a way to programmatically upload image files to ArcGIS Image for ArcGIS Online? There doesn't seem to be an Upload operation in ImageServer and I couldn't find anything applicable in ArcGIS REST API.
If there is no way to upload images to Image Services then are there other way to share image files programmatically with AGOL?
GilMastrapa
Hello again. I ran the create imagery layer routine on the web app. When choosing dynamic Imagery layers, i'm able to create image mosaics, BUT NOT image collections. Images below:
kaander08
I am looking to create a similar workflow. Did you have any progress with this?
JeffreySwain
Ok so there is a problem with the org with image collections. Also it appears you are using netCDFs can you tell me which version of netCDF you are using?
GilMastrapa
Yes, it seems to be a problem with our org and image collections. We are using NetCDF4, latest version. It works without issues on copy_raster function. Is there any checklist that we may review?
