Deep Learning graphic card requirement
12062
18
10-18-2019 10:12 AM
VHolubec
Hello,
I would like to ask, what is the minimal requirement to graphic card for deep learning in Esri (Python API learn module / ArcGIS PRO - Deep learning tools).
I have installed as documented - fastai=1.0.39 pytorch=1.0.0 torchvision, and it seems that everything works well. The probelm begins with data.show_batch() where I get error - Found GPU0 Quadro K4000 which is of cuda capability 3.0
It seems, that this GPU is no longer supported by underlying PyTorch.
I have 2 questions:
1) would it be possible to document it somewhere - which cards are supported and which does not
2) Is there any workaround how to run Deep learning on machine with Quadro K4000?
Thank you.
Vladimir
Vladimir
DanPatterson_Retired
from the help, if you downloaded it, in...
GPU processing with Spatial Analyst
Currently, only NVIDIA GPUs with CUDA compute capability of version 3.0 or later are supported.
There are more topics and discussion with a 'cuda' search in the help files
VHolubec
Dear Dan,
It CC 3.0 would be supported by PyTorch - the NVIDIA CUUDA K4000 should works fine by - CUDA - Wikipedia. But as Shaun Walbridge wrote CC 3.5 is needed and there K4000 is really not supported.
Vladimir
ShaunWalbridge
OK, I expect some of these issues to be worked out before the release goes final, and for the documentation to be clarified around what is happening. If you do have specific issues with Python packages in the beta, please feel free to use the EAP forum to post details and we can take a look.
Cheers,
Shaun
VHolubec
Dear Shaun,
this issue I met in Jupyter from PRO Final 2.4. I don´t know now, what Learn Module version was there. Testing on 2.5 is still on my To-Do list.
Vladimir
ShaunWalbridge
OK, yes if you could test on 2.5 that's helpful since the Python API version included (1.7.0) has a significantly different arcgis.learn module. If you think the error handling for environments with insufficient CUDA compute versions should be improved, I recommend adding an issue to the Python API repository: GitHub - Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python
Cheers,
Shaun
VHolubec
Dear Shaun, ok, thank you. I will duplicate this issue to the github. Thank you for help.
Vladimir
Robert
PyTorch
supports windows
Kory Kramer
Can you pass this on the appropriate team if it isn't in the Imagery and Remote Sensing‌ realm
KoryKramer
Esri Community Moderator
For questions/problems with PyTorch installation, maybe Shaun Walbridge‌ could help more than somebody in the imagery space...
