G'day.
I have trained a deep learning model to detect Grey Headed Flying Foxes camping in trees using both the 'export training data for deep learning' and 'train deep learning model' tool. The model can detect a large portion of bats (still needs more training) however I would like to run the 'Compute accuray for object detection' in order to determine the accuracy of the model. But when I run the tool I receive the following error message:
"ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (ComputeAccuracyForObjectDetection)."
Here are my parameters for the tool:
Detected Objects: DSC05728_Detected_Objects
Ground Truth Features: DSC05728_labels
Outpute Accuracy Table: C:\ArcGIS_Pro_Machine_Learning\RGB_Training_Project.gdb\DSC05728_Detected_objects_Acc
Output Accuracy Report: C:\ArcGIS_Pro_Machine_Learning\DSC05728_Detected_objects_Acc.pdf
Detected Class Value Field: GHFF
Ground Truth Class Value Field: GHFF
Minimum Intersection Over Union: 0.5
Mask Features: N/A
Extent: Default
If anyone has any idea on how to fix the error that would be much appreciated
All my ArcGIS files are being saved into the same folder called ''ArcGIS_Pro_Machine_Learning"
Below are screenshots of my attribute tables and the image in question.
