Problems with mosaic dataset
24381
12
06-30-2015 02:00 PM
MihaKlemencic
I am working with mosaic dataset and I found a problem. If I run tool Add rasters to mosaic dataset with enabled Update overviews I get this messages:
  • Error: 8004206f: Could not initialize the mosaic dataset's parallel processing engine.
  • Error: 80040213: Configuration RasterCommander.ImageServer can not be started.
  • Server Object instance creation failed on machine MIHA.
  • Image Server is not supported with the current license.
The last one is strange because I work with ArcGIS Desktop not Server.
But the last thing is very strange. If I wait some seconds after the problem is reported and then close dialog box, the overviews are created for entire mosaic dataset.
I have installed ArcGIS 10.3.1 with 64-bit geoprocessing.
Can somebody explain this issue?
Message was edited by: Miha Klemencic
Tags (1)
JayantaPoddar
Hi Miha,
Try this:
Go to Environment Settings (in tool's dialog box) > Parallel Processing. Define the parallel processing factor as 0 (zero). Run the tool. Any error?
Think Location
JayantaPoddar
Hi Miha,
Try this:
Think Location
MihaKlemencic
Problem solved
Thank you, Jayanta!
JuanPeralta1
I have the same problem, although in my case I get it creating a cache ("Manage Tile Cache" tool, ArcGIS Desktop 10.3), but setting Parallel Processing=0 does not solve it. Anything else to try?
AlessandroValra
Using "Manage Tile Cache" tool in ArcMap 10.4.1 this has fixed the problem for me as well.
Mandalorian
4 years later and this suggestion resolved the problem for me as well! Thanks, Jayanta Poddar‌!
ingeoivanherrera
Hi JayantaPoddar1, I got the same message when using the fill tool, but your recommendation solved the problem. Thank you!!
JuanDavidMercadoLeal
Thank you so much!
BabithaGanesh
Thank you so much
Wandabwa_Isaiah
This solution worked perfectly to solve the same error I was experiencing in Arcmap version 10.8. Thank you so much!
