Problems with mosaic dataset
24745
12
06-30-2015 02:00 PM
MihaKlemencic
I am working with mosaic dataset and I found a problem. If I run tool Add rasters to mosaic dataset with enabled Update overviews I get this messages:
  • Error: 8004206f: Could not initialize the mosaic dataset's parallel processing engine.
  • Error: 80040213: Configuration RasterCommander.ImageServer can not be started.
  • Server Object instance creation failed on machine MIHA.
  • Image Server is not supported with the current license.
The last one is strange because I work with ArcGIS Desktop not Server.
But the last thing is very strange. If I wait some seconds after the problem is reported and then close dialog box, the overviews are created for entire mosaic dataset.
I have installed ArcGIS 10.3.1 with 64-bit geoprocessing.
Can somebody explain this issue?
Message was edited by: Miha Klemencic
Tags (1)
HsuYee
how to solve this (ERROR 999999: Error executing function.
Failed to create raster dataset
Failed to execute (Int).
Failed at Fri Mar 22 19:34:56 2024 (Elapsed Time: 0.24 seconds)
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
at ESRI.APWR.ApHydro.ArcHydroOp.FillSinks(ApLayers& aplayers, Boolean useIsSink, Boolean fillAll, Double fillLimit, ITrackCancel trackCancel, IGPMessages messages, String& exMessage) in C:\Builds\23\s\ArcHydroTools\src\ApHydro\ArcHydroOp.vb:line 65432
Failed to execute (FillSinks).
Failed at Fri Mar 22 19:34:56 2024 (Elapsed Time: 1.27 seconds))
ModyBuchbinder
I have the same problem (sometimes). Setting the Parallel Processing to zero make the machine using one CPU for the tool.
When you work on a strong machine with many CPU's and the process is very long using 1 core only is not a good solution.
Is there anything on the machine setting that can cause this problem?
DweepPandya
Do you get any solution for this problem?
