Image classification wizard not enabled?
22887
14
09-28-2017 08:13 PM
ChrisWilson2
Hi guys,
I have been allocated a spatial analyst licence for Arc Pro by our administrator and seem to be able to use the image classification tools in ArcToolbox.  Before this I need to generate training areas for a maximum likelihood supervised classification but the image classification tools are greyed out including the wizard - this seems the only way to generate training areas within Pro, and I'd like to do it that way.  Any ideas as to why I can't see the tools?  I am trying to also check if there is an issue with the install as well, but for now I'm puzzled.
I am running 2.0.0
Chris
RandyWiggins
I had a similar issue with the Classification Wizard being grayed out in ArcPro. After a lot of trial and error we discovered it was due to the fact that I was not creating my projects using the Map.aptx template. Once I started using the Map.aptx template, the issue disappeared.
DanPatterson_Retired
Strange.... I always start mine with Blank
VinayViswambharan
Hi - You typically run into this issue, if you dont have an image selected in your contents pane.
regards,
Vinay
leticia_duarte
The classification wizard in only enabled for  3-band, 8-bit images. Maybe your raster is floating point or other format non-available for this wizard.
leticia_duarte
Make sure that the Image Analyst extension is available on the licensing area. If under the column "Licensed" it appears as "No", it means you have to access ArcGIS Online to select you as a member of your company and enable the extensions needed. Also, you can try to replace the default URL (https://www.arcgis.com/)  of the licensing Portal, to the URL of your company (https://organizationname.maps.arcgis.com/), in case you have one.
Read the details about this in here: https://pro.arcgis.com/en/pro-app/latest/get-started/start-arcgis-pro-with-a-named-user-license.htm
