ArcGIS Javascript API change Home Button image
6850
05-20-2015 10:34 AM
JosephRogan
How can I change the image/icon of the HomeButton (and other) widgets easily using the ArcGIS Javascript API?  Do I need to need to follow something like the "Create a Re-usable Widget" guide, or is there an nice easy way to just specify my own image url?
Thanks!
TimWitt2
JosephRogan
Thanks!
ChrisSergent
If this worked for you I can mark Tim Witt's answer as correct. I don't know if you see that option since I created this group.
JosephRogan
Yes, that helped.  In addition to the info in the links I also added some css, because by removing the span's text, there was essentially no element left to click on and trigger the action of the home button.  I had to make the span's text cover the entire button, not overflow, be transparent and not selectable. Actually there was a little more because I had to make the selectable text transparent as well since my work only uses ie9 and some of those items don't work.
.customButton span {
    color: rgba(0,0,0,0);
    line-height: 35px;
    display:block;
    overflow:hidden;
    -webkit-touch-callout: none;
    -webkit-user-select: none;
    -khtml-user-select: none;
    -moz-user-select: none;
    -ms-user-select: none;
    user-select: none;
