Custom styling for HomeButton
6325
02-26-2014 11:32 AM
TerryRichards
I have added a HomeButton to my map, but want to use custom styling to make it look more like the zoom widget. I have got it working ... except for the fact that the word 'Home' now appears over the button. What am I missing?
This is the javascript to add the HomeButton:
this.homebutton = new Homebutton({
[INDENT]map: this.map,
visible: true,
theme: "homeButton",
extent: new esri.geometry.Extent(config.initialExtent)
}, "homeButtonDijit");[/INDENT]
this.homebutton.startup();[/INDENT]
This is the CSS:
/*home button custom styling*/
.homeButton {
    -moz-user-select: none;
    background-color: #FFFFFF;
    border: 2px solid #666666;
    border-radius: 5px 5px 5px 5px;
    cursor: pointer;
    padding: 7px;
/*class for the home button*/
.homeButton .home {
    background-image: url("../images/home.png");
    width:16px;
    height:16px;
    background-color: white;
/*Containing class for the widget's node*/
.homeButton .homeContainer {
    border:none;
/*Class put onto the home button while the home extent is loading*/
.homeButton .loading {
    background-image: url("../images/loading.png");
    width:16px;
    height:16px;
ManishkumarPatel
Hi Terry,
You can try to inspect the element and verify. Also you could refer to the below sample:
https://developers.arcgis.com/javascript/jssamples/widget_home.html
If possible can create a jsfiddle and share so its easier to troubleshoot.
Regards,
Manish
this.homebutton = new Homebutton({[INDENT]map: this.map,
visible: true,
This is the CSS:
.homeButton {
    cursor: pointer;
    padding: 7px;
.homeButton .home {
    width:16px;
    height:16px;
    border:none;
    width:16px;
    height:16px;
ManishkumarPatel
Hi Terry,
Regards,
Manish
visible: true,
This is the CSS:
.homeButton {
    cursor: pointer;
    padding: 7px;
.homeButton .home {
    width:16px;
    height:16px;
    border:none;
    width:16px;
    height:16px;
TerryRichards
Thanks Manish. Yes, inspecting the element did help ... as you can see somewhere in html that is rendered for the widget there is a span with inner html 'Home'. I will have to inspect the widget's default styling to see what is done to hide it. In the mean time I have just set the font colour of my home class to transparent. Bit of a hack, but will work for now.
Terry
MattDriscoll
Terry
That text is there incase someone wanted the text instead of an icon or image. You can just use this to hide it:
[HTML].homeButton span{display:none;}[/HTML]
