How to get the Home button between the two default zoom sliders?
11049
13
08-26-2014 11:30 AM
AlexGole
Hi all,
I am trying to insert vertically the home button in between the zoom sliders ( + and  -). How can I achieve that?
Thank you,
Alex
RobertScheitlin__GISP
Alex,
  I do this in my maploadhandler function:
                initialExtent = map.extent;
                dojo.create("div", {
                    className: "esriSimpleSliderHomeButton",
                    title: 'Zoom to Full Extent',
                    onclick: function () {
                        if (initialExtent === undefined) {
                        map.setExtent(initialExtent);
                }, dojo.query(".esriSimpleSliderIncrementButton")[0], "after");
                //get rid of the javascript:void(0) statusbar message.
                domAttr.remove(dojo.query(".action.zoomTo", map.infoWindow.domNode)[0], 'href');
                domAttr.set(dojo.query(".action.zoomTo", map.infoWindow.domNode)[0], 'style', 'cursor:pointer;');
And the css:
.esriSimpleSliderHomeButton {
    border-bottom: 2px solid #666666;
    background-image: url(../images/zoomExtent.png);
    background-repeat: no-repeat;
    background-position: center;
    cursor: pointer;
.esriSimpleSliderHomeButton:hover {
    background-color: rgb(102, 102, 102);
    background-color: rgba(102, 102, 102, 0.9);
Alex,
And the css:
    cursor: pointer;
AlexGole
Thank you, That is super helpful! I was looking for it for a long time now!
Alex
DavidColey
MVP Frequent Contributor
Good one Robert, I'd been looking for this one for some time myself-
Thank!
DavidColey
Hi Robert-
Can you tell me where in the api you are pulling the home slider png?
KenBuja
MVP Esteemed Contributor
This is an image that you have stored somewhere. You can also use a data URI
DavidColey
Right, thanks Ken.  I thought I could pull it out of my downloaded api somewhere, but this will work too. Thanks for the data URI tip...
KellyHutchins
Esri Notable Contributor
If the look and color of the image suits your needs the home button in the JSAPI has a home image you can use:
http://jsdev.arcgis.com/3.11/esri/dijit/images/home.png
If you want to modify the image you can save a copy of it locally then make the necessary edits and specify your new image as the background-image via css as shown by Robert.
DavidColey
Thanks Kelly et al-
I ended up borrowing the home_locate.png from arcgis online at
http://cdn.arcgis.com/cdn/4922/js/esri/arcgisonline/map/css/images/home_locate.png
Then, I just created a simple on load function and added Robert's code:
//on function for home button slider
mapMain.on("load", addHomeSlider);
    function addHomeSlider() {
  //let's add the home button slider as a created class, requrires dom-Attr
                     if (extentInitial === undefined) {
                         extentInitial = mapMain.extent;
                       mapMain.setExtent(extentInitial);
Since I'm not utilizing a progress bar for this app, I excluded
the code for displaying the status bar message.  I then modified the css:
    border-bottom: 1px solid #666666;
    background: url(../css/home_locate.png);
Which produced this nice clean look:
DanielSmith
does this still apply to version 3.16+? I cant seem to get it to work correctly. The new button is there but the zoom out button is not visible
