How to get the Home button between the two default zoom sliders?
11097
13
08-26-2014 11:30 AM
AlexGole
Hi all,
I am trying to insert vertically the home button in between the zoom sliders ( + and  -). How can I achieve that?
Thank you,
Alex
DanielSmith
nm. removed the absolute position and was good to go.
VeenaHosur
Robert,
can you tell me how to change icon of arcgis navigation tools
RobertScheitlin__GISP
Veena,
  Actually those are text and not icons:
<div id="map_zoom_slider" class="esriSimpleSlider esriSimpleSliderVertical esriSimpleSliderTL" style="z-index: 30;">
    <div class="esriSimpleSliderIncrementButton" title="Zoom In">
        <span>+</span>
    </div>
    <div class="esriSimpleSliderDecrementButton" title="Zoom Out">
        <span>–</span>
    </div>
</div>
So you would have to manipulate the dom and replace the span elements with an image. I have never had a desire to do this so I don't have a code sample for that.
ChrisSmith7
Honored Contributor
Veena,
Here's some example code:
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title></title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
  <style>
    html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    #map{
  padding:0;
  .increment {
  background-image: url('https://useiconic.com/open-iconic/svg/fullscreen-exit.svg');
  background-repeat: no-repeat;
  background-size: 16px 16px;
  background-position: center;
  .decrement {
  background-image: url('https://useiconic.com/open-iconic/svg/fullscreen-enter.svg');
  </style>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
  <script src="https://js.arcgis.com/3.15/"></script>
  <script>
    var map;
    require([
      "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
      "dojo/parser", "dojo/on",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser, on
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-105.255, 40.022],
        zoom: 13
      //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
   //remove +- span and replace with SVG
   map.on("load", function (e) {
       $('div.esriSimpleSliderIncrementButton').find('span').remove();
   $('div.esriSimpleSliderDecrementButton').find('span').remove();
   $('div.esriSimpleSliderIncrementButton').append("<div class='increment'></div>");
   $('div.esriSimpleSliderDecrementButton').append("<div class='decrement'></div>");
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'"
         style="padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
