Digitizing hand-drawn map
1435
8
04-03-2026 07:06 AM
ShareUser
Esri Community Manager
Hello, I am going to digitize a hand-drawn map in ArcGIS Pro and where wondering if any of you had some tips for where I should start, and are there som good tutorials I can watch or read?
ShareUser
The first thing you would need to do is georeference the hand-drawn map so it's of use in ArcGIS Pro.  The workflow is listed here - Georeferencing tools—ArcGIS Pro | Documentation  There's a tutorial here that will assist you - Georeference historical imagery in ArcGIS Pro | Documentation
Non-Esri resources also show how to georeference images - Georeferencing and Digitizing Map Images in ArcGIS Pro
Once the hand drawn map is georeferenced then you can digitize the points, lines, and/or polygons using the georeferenced image as a guide.  If you're new to editing, this Learn lesson will help - Edit features to create enumeration areas | Documentation
With AI, things can get even more interesting - Digitizing scanned maps using AI in ArcGIS Pro
Good luck on your project!
ShareUser
If you think you will be digitizing several maps (e.g., a map series) that have the same symbology you should consider creating an editing template before you start. This will allow you to set default values for point, line, polygon data types which will simplify adding attributes to your digital data down the road. In addition, if you don't have access to a traditional digitizing table (that were ubiquitous in 1990-2010) consider scanning the document then use heads-up digitizing.
see: Introduction to editing templates—ArcGIS Pro | Documentation
ShareUser
Will the data from the hand drawn map have any accuracy requirements? If so, and have the necessary data on the map consider rebuilding from cogo/data entry techniques vs just digitization. If you have multiple adjacent maps, this will keep you out of trouble when edges don't line up.
ODWC_GIS
Hello there!
I'm a bit confused.  Is "ShareUser" being used by multiple people, or are you one person asking and then answering your own question?
LindsayRaabe_FPCWA
MVP Regular Contributor
The original post is in the ArcGIS Pro question board and has been cross posted to GIS Life (either by an Esri user or MVP). ShareUser shows the replies made in other locations are automatically reposted here as well for completeness. You will see it states the Source Community and the Source Author Name in each "ShareUser" post.
Read here for more info: How to use the Share Tool - Esri Community
Lindsay Raabe
GIS Officer
Forest Products Commission WA
ODWC_GIS
This is the second strangest change AGOL has implemented in the last 3 months.  I see that in the Original Posting Location Thread, you and I (who are interacting with the thread in the GIS Life Board) are listed as @ShareUser
Won't replies to Participants get horribly mangled?
ShareUser
Sorry for the confusion folks!  I hadn't seen this new 'cross-posting' convention before.
It feels needlessly complex and/or convoluted.
JesseCloutier
Hi all, the way the Share Tool works requires that a shared account be the source that manages copies of posts and comments. To help clear up confusion and aid everyone in recognizing differences between different users, you can still see the original author of a post or comment shown near the username. We recognize there is room for improvement with the feature, but I hope this helps!
Jesse Cloutier
Community Manager, Engagement & Content
