Wrong minimum bounding circle in UTM
1342
12-05-2012 12:35 AM
Durga_PrasadD
I have found Minimum bounding circles for some polygon features.Most often I find that some features lying outside the resulting circle.
Is this a bug in ESRI ArcGIS?
I used an alternative method of finding bounding circle...Find the envelope>Get the centroid>Get the farthest vertex from centroid and  use  ICircularArc interface to draw circle.This seems to provide correct result.
Any suggestions?
JakeSkinner
Esri Esteemed Contributor
Hi Durga,
What version of ArcGIS Desktop are you running (including service packs)?  Do you have a sample dataset you could upload that exhibits this behavior?
DanPatterson_Retired
Durga_PrasadD
I am using 9.3.1. Attaching the shape files that I used in UTM projection
1)Points.shp---My features of interest
2)BoundingBox.shp----Envelope for above points
3)BoundingBox_Centroid.shp---Centroiod of this envelope
4)BoundingBox_Centroid_Generat.dbf---Near table created by Proximity Analysis tool
5)BoundingCircle.shp---Buffer created using largest distance(3582.146565 meters in this case)
FID 1275 is the farthest vertex in Points.shp from centroid ..this seems to lie oust side the BoundingCircle
I noticed an interesting thing...I have used 'Smooth' tool from Advanced Editing feature,with a threshold of 0.09(which is the measured deviation from circle boundary to the outlier point).This is resulting in a circle that passes through the outlier point just as I need.
Unfortunately,this is true only during editing session.The changes get lost when I save the changes brought in by 'smooth' .
