Using Python, can't get Batch Project outputs to save in a feature dataset
6804
11
09-14-2011 05:35 AM
JamesGraham
When attempting to batch project in ArcGIS (using either arcpy or arcgisscripting), I cannot get my geoprocessing results to drop into the feature dataset that I specify. The results instead are dropped in the root of the Geodatabase (*.mdb).
Here's an abbreviated version of what I have so far:
import arcgisscripting, os
gp = arcgisscripting.create(9.3)
#set date
dmy = datetime.now()
currentDate = str(dmy.month) + "-" + str(dmy.day) + "-" + str(dmy.year)
outputfolder = gp.getparameterastext(0) #where we're going to drop the gdb
citydata = gp.getparameterastext(1)
gp.workspace = outputfolder
projectedfolder = os.path.join(outputfolder, "projected")
gp.CreateFolder_management(*os.path.split(projectedfolder))
gdb = "Projected_Data_" + currentDate + ".mdb"
#set coordinate system
outputCS = gp.CreateObject("SpatialReference")
outputCS.createFromFile(os.path.join(gp.getinstallinfo()['InstallDir'], "Coordinate Systems\\Geographic Coordinate Systems\\North America\\NAD 1983.prj"))
transformation = ""
gp.AddMessage("Creating City feature dataset")
gp.CreateFeatureDataset(os.path.join(projectedfolder, gdb), "City", outputCS)
gp.AddMessage("Loading in City feature classes")
arcpy.BatchProject_management(citydata, os.path.join(projectedfolder, gdb, "City"), outputCS, "", transformation)
Obviously, the part I'm having trouble with is the Output Path in the last line. I've also hard-coded the path to the "City" feature dataset, but still drops it in the root. Any ideas?
NobbirAhmed
Esri Alum
Hi Gregory (and all others interested), good news is that finally we have implemented the desired behavior in 10.1 🙂
It works for Project and Batch Project tool.
Please let us know if you find any anomaly in expected behavior.
SharifulIslam
Hi all,
It may be a general problem, by the way.
Does the problem of outputting geo-processing in "Feature Dataset" still remains?
I am failing to output result of  "arcpy.JSONToFeatures_conversion" tool in "Feature Dataset" in ArcMap 10.3 (Advanced). When i run script, output goes directly into the parent "Geodatabase" though the projection of that "Feature Dataset" is the exact of the output of that tool.
Shariful
