using modelbuilder to generate maps
2659
03-12-2012 02:58 PM
RennaTruong
I am working on a project with the goal of producing a map for each floor of every building on a university campus. What would be the best way to proceed with this project using modelbuilder? I have two layers one of building footprints and the other containing each floor. I do not have much experience in using modelbuilder and do not know where to begin.
DarrenWiens2
I'd forget about ModelBuilder. This is what Data Driven Pages are for (with ArcGIS 10). If you have 9.3, use DS MapBook.
RennaTruong
Thank-you for the help. Although Data Driven Pages does not produce the results I want. Data Driven Pages creates a map book of each of the building (with all the floors overlapping) and not each floor of each building.
Does anyone know of a method to produce a map of each floor of each building without manually doing so?  There are over 500 floors, thus, an automated model would help me save a lot of time. As well, in the attribute table there is a building_Floor_ID which can be used to identify each floor.
DarrenWiens2
That's what Page Definition Queries are for, using Data Driven Pages.
RennaTruong
@dkwiens
Thank-you so much for your help! I did not realize that function was available.
