Using InsertCursor method with DATE type field.
6148
07-04-2010 12:16 PM
BorisBorisov
How can I use the InsertCursor method with DATE type field? I'm trying to use this code, but have an error (progresscheck - table in my gdb, date - field with date data type):
rows = gp.InsertCursor(progresscheck)
row = rows.NewRow()
row.date = "22.10.2010"
or
row = rows.NewRow()
row.date = time.strftime("%d.%m.%Y",time.localtime(time.time()))
Error message:
File "C:\work\progress\1\1.py", line 61, in <module>
RuntimeError: ERROR 999999: Error executing function.
KimOllivier
Honored Contributor
An interesting problem that is glossed over in the help.
I solved this by creating a table with a date field, populating it and then reading them with a SearchCursor.
When Python reads/writes a date field using a cursor it expects a date object using the datetime module. So I found that you have to create and manipulate dates as datetime objects.
The datetime module is actually very convenient and cursors work for everything except NULL values.
# datetest
import arcpy,datetime
ws = "c:/home/python/datetest.gdb"
arcpy.env.workspace = ws
rows = arcpy.UpdateCursor("fcdate")
for row in rows :
    print row.timestamp,type(row.timestamp)
    if row.timestamp == None:
        row.timestamp = datetime.datetime.now()
    else :
        row.timestamp = row.timestamp + datetime.timedelta(hours=10,minutes=30,seconds=15)
    rows.updateRow(row)
del row,rows
Here is an example featureclass with an existing date field. It had a few dates and a null record.
Note that you can read the dates and print them because a date object has a default 'representation'. It is not a string, you can just print the object as a string without casting.
Note how you increment a date, using a timedelta object.
You also have to trap null dates.
I have used a file geodatabase (not a shapefile) because I expected it to handle a full datetime not just a date as in dBase or INFO.
More help in the pythonwin help for python for the datetime module.
KimOllivier
Honored Contributor
How hard could it be??
Unfortunately this example script is read-only at 9.3. You will have to upgrade to arcpy to insert dates as I have found to my cost.
1/08/2010 <type 'unicode'>
  File "C:\Python25\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 310, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\eudora\Attachdir\datetest93.py", line 16, in <module>
TypeError: coercing to Unicode: need string or buffer, datetime.timedelta found
# datetest93.py
# convert to 9.3 after a problem
import arcgisscripting,datetime
gp = arcgisscripting.create(9.3)
ws = "d:/workspace/datetest.gdb"
gp.workspace = ws
rows = gp.UpdateCursor("fcdate")
row = rows.next()
while row :
        row.timestamp = datetime.datetime.now() ## fails
        pass
    else :
        row.timestamp = row.timestamp + datetime.timedelta(hours=10,minutes=30,seconds=15) ## fails
        pass
    rows.updateRow(row)
    row = rows.next()
del row,rows
