Using Calculate Field in python?
4965
20
01-06-2011 08:18 AM
BartłomiejStaroń
The tool works well in the MODEL bilder, but when it wants to convert it to the python script error occurs. All data from the column disappear.
import arcgisscripting
gp = arcgisscripting.create(9.3)
gp.workspace = "D:\\DATA.gdb\\"
TABLE = "D:\\DATA.gdb\\TABLE"
FIELD = "texx"
gp.CalculateField_management("TABLE", "FIELD", "StrConv([texx],vbUpperCase)", "VB")
What am I doing wrong??
JasonScheirer
Esri Alum
Don't quote the first two params:
gp.CalculateField_management(TABLE, FIELD, "StrConv([texx],vbUpperCase)", "VB")
BartłomiejStaroń
Still not working:(
ExecuteError: ERROR 999999: Error executing function.
Type mismatch: 'StrConv'
Failed to execute (CalculateField)
BartłomiejStaroń
Maybe I should use the cursor objects?
JoeVondracek
How about trying it with Python, since it is a Python script?
gp.CalculateField_management(TABLE, "texx", "str(!texx!).upper()", "PYTHON", "")
BartłomiejStaroń
I came up with something like this:
cur = gp.UpdateCursor("sfora_2")
row = cur.Next()
while row:
    row.texx = str.capitalize(row.texx)
print "end"
But it only replaces the first letter capitalized.
I want to have every word that begins with a capital letter.
I have some ideas but I do not know how to implement it into the script.
import re
w= "it should work"
bbb = re.split('([ ] *)', w)
''.join([each.capitalize() for each in bbb])
print ''.join([each.capitalize() for each in bbb])
ChrisSnyder
Honored Contributor
It would look something like this:
updateRows = gp.UpdateCursor("sfora_2")
updateRow = updateRows.Next()
while updateRow:
   newString = ""
   for word  in updateRow.MYFIELD.split(" "):
      newString = item.capitalize() + " " + newString
   updateRow.MYFIELD = newString[:-1]
del updateRow
del updateRows
This code would take a field value of "hello world", and trun it into "Hello World".
I think I am misunderstanding what you want to do though....
If you have a string "hello world", what do you want it to look like?
If you want everything to be upper case (e.g. "HELLO WORLD"), do this:
while updateRow:
   updateRow.MYFIELD = updateRow.MYFIELD.upper() #.upper() capitalizes every character
del updateRow
del updateRows
BartłomiejStaroń
The first script is what I was looking for.
However, I will get an error:
NameError: name 'item' is not defined
Recently I started learning Python, so sorry to ask some simple questions.
ChrisSnyder
Honored Contributor
Woops....
while updateRow:
   newString = ""
      newString = word.capitalize() + " " + newString
del updateRow
del updateRows
BartłomiejStaroń
I could have guessed.
Thanks a lot.
I hope that the next script will not need much help.
