Update Geometry while using python
1400
05-07-2010 06:56 AM
JeremyTibbetts
Hello,
I have two fields, Northing and Easting, which hold values. However, I want to relate these fields to a geometry field in the same feature class. How would I be able to do this while using python? Can you use an update cursor on the same feature class?
Jeremy
BruceHarold
Esri Frequent Contributor
Hello Jeremy
Yes, you can update your feature class geometry with a cursor writing to the shape field with points made from the northing and easting values.  Make a Point from each XY then a PointGeometry, then write the value.  Don't forget to set the spatial reference for the cursor if the feature class coordinate system is different form the XY values.
Regards
JamesOBrien
I have a detailed blog here about processing Arcgis geometry with Python:
http://geophyter.blogspot.com/2009/12/converting-feature-classes-to-kml-using.html
