Toolbox in Arcgis Pro will corrupt when script behind tool is renamed
5152
10
08-17-2022 11:07 AM
PhilLarkin1
After changing the file name of a python script in file explorer, which is referenced as a script in a Toolbox, all script tools in the toolbox will lose their name when displayed in Catalog View.
Version: 3.0.0
Creating a new script will result in the error below:
Typical context menu for dead script tools is missing:
PhilLarkin1
Not only does this corrupt the toolbox, it corrupts the entire project!
DrewFlater
Hi @PhilLarkin1 , sorry you have experienced this!
When I try the same steps you described, the tools in the toolbox are not corrupted, and when I open the tool properties it simply says on the Execution page that the Script file at the previous path no longer exists.
If you report the bug to Esri Support we can further troubleshoot the problem. If you're willing to upload the atbx in a zip here we can start looking at the problem ASAP.
PhilLarkin1
Thanks for your help. I've attached a toolbox.
DrewFlater
@PhilLarkin1 which tool's executable script did you rename to cause the initial problem?
PhilLarkin1
This is just one of many test toolboxes; it is not the original toolbox that I encountered the problem. At this point I believe my project is corrupt. I simply can not create a script in a toolbox without getting the HRESULT EFAIL error described earlier.
DrewFlater
We can see your test tools in the atbx: asdfasdf, dfgdfg, dsfsdf, Model, Script, sdfsdf, yrdy, ZX.
But the tool list inside the toolbox has lost those tool references.
Can you further explain how you were modifying the Python script file name in Windows File Explorer? Were you renaming a file internal to the atbx archive? It seems all the script tools in the toolbox have embedded/internal Execution script files, rather than reference paths to external standalone .py script files.
PhilLarkin1
I reinstalled ArcGIS Pro hoping this would fix the issue. Seems I still can't create scripts. Is there a registry setting i could check?
I've attached another toolbox.
DrewFlater
In this new toolbox I can see one tool, DeleteVersionGetParcels, but the tool is devoid of any properties or parameters. The script tool refers to an embedded script source that only includes this code
# Geoprocessing Script Tool
arcpy.AddMessage('Hello World')
So there is no reference to an external script file, which may or may not have been renamed.
I think it will not be productive for me to try to troubleshoot the problem further, it seems to be a problem with your system or installation of ArcGIS, or there may be some other steps or conditions that are hard to diagnose via a community forum. If you are able, please contact Esri Support to explain the problem you are having and get hands on troubleshooting and support.
PhilLarkin1
Thanks for giving it a shot.
