TIN to Raster
7507
15
11-06-2015 03:40 AM
KONPETROV
Hi, I want to use 3 different series of Data in the form of TIN for a viewshed analysis. I thought to convert them to raster because as I saw, I cannot do a viewshed in the form of TIN. My problem is that when I convert TIN to Raster from the 3D Analysis toolbox, although the resolution in TIN is 10meters, in Raster is almost 30meters. Why is that? Can't i convert it to raster and to have the same resolution? The analysis at my raster is being made for 30 meters resolution or for 10 meters at last?
Thank you very much
DanPatterson_Retired
Yes as I stated earlier.  The link to the help topic is in your viewshed thread.
JayantaPoddar
Hi Kon,
Did you try changing the environment setting of the tool?
Think Location
KONPETROV
Yes, the default were the numbers I wrote above
LukeSturtevant
Kon,
If you are still having this issue, maybe you would consider uploading one of your tins so that we can better understand what is happening here.
KONPETROV
Luke thanks for your interest. I don't have that issue, i just put the resolution i wanted at the cell size. My wonderies are just when I have a TIN from 10 meters resolution elevation data, and I create a raster from that TIN  with resolution bigger than 10 meters, for example 1meter resolution (that I define every time), what are the restrictions of that step, you  know the theory. This is mainly my problem, the theory beyond that. Thanks a lot.
Tin to raster How TIN To Raster works—Help | ArcGIS for Desktop
raster to TIN How Raster To TIN works—Help | ArcGIS for Desktop
In either case, either data structure is only as good as your input data, and that includes considerations of accuracy and in the case of precision you also need to look at spacing between the intervening point (if variable), the type of interpolator or aggregator in the case of rasters.
