TIN to Raster
3348
08-24-2014 01:36 AM
AretiSamara1
How could I specify the output raster's origin, while using Tin to Raster Tool?
DanPatterson_Retired
If you are using Arctoolbox, the Environments tab in the bottom right of the tool will have options to set analysis properties
in the help file on Tin to Raster you can specify the extent which obviously you can determine the origin from those coordinates
AretiSamara1
Thank you, but when I open the "TIN to Raster" tool there is no option to specify the extent.
AretiSamara1
Thank you!
