Thinning polygon vertices
1747
10-20-2010 11:31 AM
EdSchoon
I have a polygon layer which has some "re-entrant" areas which are extrememly small, but still cause problems. I am wonering if there is a tool to "thin" the number of vertices making up the polygons, maybe to "no closer than 25 feet". I believe this would correct the "re-entrant" areas. I would like to run it on the whole layer.
I am running ArcEditor 9.3.1
Thank you for your time & suggestions
BBicking1
See if Simplify Polygon [Cartography/Generalization] or Eliminate or Elimiate Polygon Part [DataMgmt/Generalization] gives you the result you want/need.
Barbara Bicking
Geoprocessing Team
EdSchoon
Thank you for trying to answer my question. I think the tools you mentioned would work if I had ArcINFO, but I only have ArcEditor. I do believe I have found the tool that I need: Advanced Editing>generalize. I am still testing it with my data to be sure it provides the output I am looking for.
Again, thank you for your time
Ed S.
NiklasNorrthon
The SimplyfyPolygon tool which does exactly what you want according to your description requires ArcEditor license according to ArcGIS 10 desktop help.
