There was a failure during processing. Check the geoprocessing results window for det
12868
03-15-2012 12:32 PM
MariaDumitru
Hi all,
I'm receiving this message when I try to use field calculator in the attribute table to do this operation:
[PERCENT_A] /10* [Class_A_ne] + [PERCENT_B]/10* [Class_B_ne]+ [PERCENT_C]/10* [Class_C_ne]
Can anyone help me in this matter?
Thanks a lot!
Maria
MarcinGasior
Check the Results window (see figure) for specific error message. It usually help to determine the problem.
[ATTACH=CONFIG]12755[/ATTACH]
The most common error in calculation is using text values instead of numeric.
If it's the case try using Cint([field_name]) or Cdbl([field_name]) for converting respectively integer type values and double type values from text.
MariaDumitru
Thank you so much for your help. I will check now.
Maria
