Table to Geodatabase
1034
06-01-2012 07:13 AM
LarissaPizzolato
Hello,
I am trying to import .txt files (tables) into a geodatabase (as a table) using the code below, but am getting the following error:
      inTables = inTables + " ; " + tb
TypeError: can only concatenate tuple (not "str") to tuple
Does anyone know what might be causing this and how to fix it?
Thank-you
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# To import the .txt tables into the geodatabase
# the folder where the original table files are stored
inFolder = "C:\\w\\x\\y\\z\\mnth"
# the geodatabase where the tables will be imported to
outGeodatabase = "C:\\w\\x\\test.gdb"
inTables = ("*", "txt")
gp.Workspace = inFolder
tbs = gp.ListTables()
tb = tbs.Next()
while tb:
    if inTables:
    else:
        inTables = tb
    tb = tbs.Next()
# Put a try-except-look around the tool, in case an error occurs
try:
    print "Importing the following tables: " + inTables
    gp.TableToGeodatabase(inTables, outGeodatabase)
except:
    # If an error occurred, print the messages returned by the tool
    print gp.GetMessages()
print "Completed: Table Added to Geodatabase"
BruceNielsen
You have inTable defined as a tuple (inTables = ("*", "txt")), then you are trying to append a string to it, which is causing the error. Initialize inTables to an empty string, then change the if statement in the while loop to test against the empty string:
inTables = ""
tb = tbs.Next()
while tb:
    if inTables == "":
    else:
        inTables = tb
    tb = tbs.Next()
Please use CODE tags when submitting code to the forums. It preserves the indenting.
FabianBlau
Please use the CODE-Tags ('#'-Button from Editor).
inTables is a Tupel:
Maybe you mean:
inTables = ""
So it is an emtpy string.
if inTables:
is True, if inTables is not! empty.
Try:
inTables = ""
tb = tbs.Next()
while tb:
tb = tbs.Next()
gp.addMessage(inTables)
