?Table Select does not work in Model Builder
9124
15
12-17-2015 03:34 AM
gilweil
Hallo,
I'm trying to create a model that uses values from a single table, in order to perform a different calculation for each raster in a file.
Each raster is represented in the table by a row that contains the raster unique name (string), and 2 other fields with the numeric values for the calculation (slope & intercept).
I use "Iterate rasters" to go through the files, and "Table Select" where I select the relevant row for the parameters, by using %Name% (from the iterator) = name (the raster name in the table).
Doesn't work... the model gets stuck in the "Table Select" stage.
Does anyone have any idea why?
I attached python code and image of the model.linear_correction_parameter_from_table_img.png
Thank you!
LukeSturtevant
Okay try this:
Add a Calculate Value​ tool in to calculate a valid name for the output table the code would be
"%Name%".split(".")[0]
Then change the output table name to t_%TableName%
gilweil
Thanks a lot
I'll try it on Sunday
gilweil
Perfect thanks!
gilweil
Now I recognize another problem...
The model (Table select) selects only the first row in the table, the following outputs are empty tables
LukeSturtevant
I'm not sure why it would only be running for one table entry for you. I've attached an edited toolbox. This seems to work with the example data you provided just fine on my end.
gilweil
Thank you again,
Your solution works great, but I I came across other two problems I have not seen before:
1. The select tool is case sensitive
2.  The model does not overwrite properly the previous outputs
After I treated these specific problems, everything works properly.
