Splitting a polyline shapefile using a fishnet shapefile?
6019
9
07-08-2014 08:19 AM
AlexanderPeace
I have a polyline shapefile that I would like to split into boxes of equal size. I have been told the best way to do this is to use a fishnet grid, is this the best way?
At the moment I have a fishnet polygon shapefile and I am attempting to use the 'Split (Analysis)' tool in Arc Map 10 but I get an error:
"Field Shape not of type TEXT"
Any help appreciated,
Regards,
Alex
DuncanHornby
MVP Notable Contributor
Well for starters just use the FID field, that's unique?
DuncanHornby
Are you setting the Shape field to be the Split Field? I think this parameter needs to be a field containing a unique ID, so a numeric field like ObjectID or FID.
AlexanderPeace
Hi Duncan,
Thanks for your help. Yes I am setting the Shapefile generated by the fishnet as the split field. What do you keen by a field containing a unique ID? How can I generate one of these?
Alex
DuncanHornby
The third parameter of the split tool, it should be a field that holds a unique ID such as the FID field.
AlexanderPeace
Ok, so how would I create something which contain an appropriate field for this purpose?
Alex
DuncanHornby
AlexanderPeace
Got it!! Thanks!
Alex
AlexanderPeace
The key to this if anybody else tries is to make sure that the Field you are using to split is set to 'Text'
Alex
BruceHarold
Esri Frequent Contributor
Hi
Despite being slightly flamed by Duncan H. I can offer:
http://www.arcgis.com/home/item.html?id=9398bd2232cb4c8490b0b05015364d28
Except you'll need to make a minimum bounding rectangle by width from your polyline first.
BuzaVictoria
useless
