Spatial Selection; points near polygon edge
2107
11-06-2020 07:18 AM
JoeBorgione
ArcGis PRo 2.6
I have a feature class of points, and a polygon feature class: I want to select the points based on their proximity to the edge of the polygon.  Is there a spatial selection that supports this?  I've tried a couple different methods but haven't found one that works.  For example:
That should just about do it....
Tags (1)
JoeBorgione
Moments later: It's a simple polygon feature class, just one polygon so I was able to use the polygon to line tool. Then I did a 'Within a Distance' spatial selection.
JoeBorgione
DavidPike
MVP Notable Contributor
Might just turn your polygons to lines then run the selection (within a distance) that way.
Edit - seen reply. Great minds...
