Spatial Join model builder
2721
04-09-2019 06:56 AM
TomPiggott
Ive been tasked with joining data from a point feature class  located within a polygon to the polygon. I know the manual way of doing:
  • Right click on polygon feature class
  • select join
  • choose join data from another layer based on spatial location
  • choose the point feature class as the layer to join
I wondered if there was:
  • a way to make it in model builder to automate it
  • to not create a new output shape file
I am pretty new to model builder so any guidance would be appreciated or a point in the right direction!
Thanks
JoeBorgione
Any tool can be added to model builder.  However, many tools, and spatial join is one of them, has an output layer: you should be able to write it to the 'in memory' space so it's not permanent .
That should just about do it....
