Spatial Join Between Raster and Vector Datasets:
3518
08-22-2013 05:13 AM
MarkEnglish
Hello:
I am required to assign elevation values to an existing point dataset. I would like to use a DEM to acheive this goal.  Is there a method of conducting a process similar to a spatial join between the point dataset (vector) and the DEM (Raster)?  Thanks in advance for any assitance.
M-
TimWitt
Mark,
maybe you could install the attribute assistant and let the attribute assistant calculate the elevation field via this trigger:
http://resources.arcgis.com/en/help/...000009r000000/
Hope this helps!
Tim
JimCousins
If you have access to the Spatial Analyst extension, use Extraction >> Extract Values to Points. It will retrieve either the cell center value under the point, or extrapolate the value based on actual location.
Regards,
Jim
