Simplify concatenated values
1160
07-18-2024 02:00 PM
PabloOliver
hello,
I am concatenating values in a Dissolve tool in a model. The concatenated values are appear correctly in the final result, however, there are multiple instances of the same value in the result. I'm looking for a way to simplify the result so that only one instance of each unique value appear in the final result.
any ideas?
thanks
PO
DanPatterson
MVP Esteemed Contributor
you could do a separate field calculation
row = 'c, d, a, b, c, e, a, c'
",".join(sorted(set([i.strip() for i in row.split(",")])))
'a,b,c,d,e'
... sort of retired...
DanPatterson
'a,b,c,d,e'
