Select points outside of polygon
4393
05-04-2021 09:22 AM
Byrd_Geology
Hello,
I need to select all the points (SampleID) outside of a few polygons (excavation areas) and I'm having trouble figuring out how to do so. I have looked at "Selection by Location" but I only have options that allow me to select the points within the polygons. Is there a way to do the opposite. I would like to then export the data points and run some site models.
Garrett
jcarlson
MVP Esteemed Contributor
"Invert spatial relationship" effectively selects "points NOT within polygons". Try that and see if you get what you're looking for.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
Byrd_Geology
Well that's a little embarrassing. Thank you so much. I cant believe I didn't notice that option.
