run model for each variable
1132
02-07-2013 03:54 PM
ChrisSeeger
Working with modelbuilder to build a tool that needs to repeat using a different  query statement
Setup:
Point layer has three attributes with the following values
field1: yes, no
field2: 1,2
field3: 0,1
a variable input parameter is setup for each and I use inline variable substitution in the query statement.
Possible permutation of these three field values I enter the following and then run one at a time, so not efficient.
yes, 1,0
yes, 2,0
yes, 1,1
yes, 2,1 ...
What I want to do is have the model automatically run using each possible combination of inputs and to export each result to display. so for a simple buffer output I have  /buffer$i$
I have tried using a list, but I still only get one output.
Any help is appreciated.
