Real Cool Stuff on Python
5023
12
10-29-2009 10:39 AM
TedCronin
So, far, the py window is pretty cool.  I type a little bit more here than with arcgisscripting, but really now, I think I will use this window over the command line window anyday even with the extra space ;).  Long Live the Python Window.  Now it doesn't beat Wing, but still pretty cool.
Should have tested this more in holistic.
BartHound
So, this looks like it would fall under the Real Cool Stuff on Python.  Thank You GP Team.
TedCronin
Spatial Reference --This is much cooler.
Much better, much more readable.
prjfile = r"C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\NAD 1983 StatePlane California VI FIPS 0406 (US Feet).prj"
spatialRef = arcpy.SpatialReference (prjfile)
VS.
sr = "PROJCS['NAD_1983_StatePlane_California_VI_FIPS_0406_Feet',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',6561666.666666666],PARAMETER['False_Northing',1640416.666666667],PARAMETER['Central_Meridian',-116.25],PARAMETER['Standard_Parallel_1',32.78333333333333],PARAMETER['Standard_Parallel_2',33.88333333333333],PARAMETER['Latitude_Of_Origin',32.16666666666666],UNIT['Foot_US',0.3048006096012192]];IsHighPrecision"
MUCH clearer syntax.
Thank you GP Team
TedCronin
dot notation
