Need to fnd the Shortest Path Between two points on streets feature class like google
839
08-11-2010 07:24 AM
abishekchalluru
Hi All,
I am working on an application in vb.net that needs to create the shortest path route between two points on a streets feature class. I would really appreciate if anyone could give me an idea or a method to proceed in achieveing this goal.
Abishek.
ChrisMathers
Thats a job for network analyst if you are planning to use linear features, but if you can convert the roads to raster you can do a cost path using spatial analyst. Those are the simplest but may require you to make a purchase if your organization doesnt already have one of those.
