Raster values based on polygon boundary
1706
01-05-2014 03:32 AM
surendarmohan
How do I obtain mean of DN values of a underlying raster layer only for such pixels that fall below a polygon boundary?
GeraldineEGGERMONT
I'm not sure I understand your question, but try this:
- convert your polygon feature class to a raster using Feature to Raster
- Use this raster as a zone raster in the Zonal Statistics tool, with "MEAN" as statistics type.
Does this help?
Geraldine
DuncanHornby
MVP Notable Contributor
If its the boundary and not the area (entire polygon) you are after then use the Feature to Line tool to convert your polygon to a polyline then use the Polyline to Raster tool (make sure snap raster environment is set to your raster) to convert the line to a raster representation of your polyline and then you can use the Zonal Statistics tool.
surendarmohan
Thanks.  Got it!
