Generalization of point data
1364
01-09-2014 02:13 AM
surendarmohan
I have a large set of spatially distributed point data with certain values.  I need to reduce the number of points.  The basis of reduction is to identify points that are within a proximity of, say 100 meters.  If more than one point exists, then a new point (located at its center / centroid) should be created which should now have the mean of all points that have been merged.
Can I do this without serious programming? May be a long but workable solution using available tool sets?
TimWitt
Surendar,
Maybe a better looking way would be a Hot Spot Analysis?
Or you could use this?
Tim
