query to select objects in an area bounded
5612
14
10-16-2014 11:13 AM
MikeHenson
really needing help with this. See the attached image. I have subdivisions represented by polygons, and within those polygons, I have more data representing sewer lines. I need to query certain size lines, within the subdivision polygon and am not sure which geoprocessing tool to use.
For example.....looking at the image.....how would I query 6" sewer lines with the North Hills Subdivisons.  Each set of data, (sewers and subdivisions) are in separate shape files.
DanPatterson_Retired
same thing...give it a try..try it through arctoolbox, and also through the main menu, they are essentially the same just different visually etc.
MikeHenson
I have just been doing a search and found it there. Sometimes I am not sure where to drill down to find a tool!
MKH
MikeHenson
Cory and Dan....I appreciate you guys staying with me on this!  I would be lost without the help of the forum. Many thanks!
good luck and keep at it
CoryMacNeil1
No problem Mike.  That is what the forums are for.  There are a lot of tools available, even people who have been working with the software for a long time don't know all of them.  Sometimes you just have to find time to play around and explore what is available.
Cheers,
Cory
