Problem with MultiValue MXD Parameter
1567
01-20-2011 08:38 AM
JohnStephens
I have a script that is supposed to automate exporting several map documents. I have it set up as a script tool. The user is prompted to enter a few things, including several MXDs to be exported. I have handled those values as a list and used the 'split' function to separate them:
mapList = string.split(sys.argv[1],";")
After that I have a loop that is supposed to loop through the above list and export the maps. However, when I run the script I get the error:
<type 'exceptions.AssertionError'>: Invalid MXD filename.
The top of the loop looks like this:
for map in mapList:
    mxd = arcpy.mapping.MapDocument(map)
I know the rest of the code works, because if I take out the 'map' variable and directly enter the file path of an MXD the script works. I assume it is something blatantly simple, but I just can't figure it out. Any help would be appreciated.
deleted-user-1T_bOHag6M8d
for map in mapList:
John,
I'm now having very much the same problem. Although, my code did work once. It seems it failed to work every time since. Did you ever find a solution?
Thanks.
NiklasNorrthon
for map in mapList:
    print 'Map Document: %s' % map
Then you get the name of the troublesome map document, which should help you solving your problem.
MichaelFedak
I am having the same problem and I have tried to use multiple map documents to see if the name is the issue. It throws the same error every time. So why can't I get an mxd name from the value table containing full paths to mxd's?
Ok my problem occurred when I grabbed the values out of the table, they were delimited with ' '.
GroundHogg
Thanks, that solved my problem, the ' ' appended to the ends, took hours to figure out what was wrong.  Now I have to wonder why ESRI decided that apostrophes should be appended to string values.
Items directly from the TOC "do not exist" all because of the ' ' , I can understand if they were from some other location, but this is straight out of the TOC.
We are not amused ESRI...
(wheres the 'duh ESRI' smiley?)
George_ChandeepCorea
I wrote a script to create thumbnails of each mxd in a directory which works fine, but I want it to also walk through subdirectories - I am getting a Assertion Error (below). I've looked through the help but can't figure out whats wrong.
Code attached.
best,
Reading mxd files from P:\2011\Job_031_TownPlanning_SeriesProduction\Working\mxd\B&L\2\Ver1
11
2\11_TownPlanning_B&L_Overlay_Ver2_Kuranda.mxd <geoprocessing Map object object at 0x15DE25E0>
Created thumbnail for 2\10_TownPlanning_B&L_Overlay_Ver2_MtMalloy.mxd
  File "P:\2011\Job_031_TownPlanning_SeriesProduction\Working\mxd\B&L\2\Ver1\MakeThumbnails-TB.py", line 25, in <module>
    mapDoc=arcpy.mapping.MapDocument(mapDocs)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 443, in __init__
    assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename")
AssertionError: Invalid MXD filename.
