PolygonZ to Raster
1819
01-13-2012 10:49 AM
IraklisKarampourniotis
Hi again,
I have a shp file with PolygonZ and I want to convert each of these (polygonZ) into rasters.
Any idea how?
DuncanHornby
MVP Notable Contributor
Iraklis,
There is a geo-processing tool called Polygon to Raster  and its found in the Conversion > To Raster toolbox.
Duncan
Iraklis,
Duncan
Hi Duncan,
Sorry but Polygon to Raster wont work because it only make the raster single value and my polygon has a slope so I need a raster that has different values per pixel relevant to the elevation (z value) of the polygon.
Thanks.
DuncanHornby
Are you saying the vertices of the polygon contain z values? You could convert your polygon to points with z values then convert these to pixels with their z values.
Yes the vertices have z values (Shape.Z).
Feature to Point returns only one point per feature (per polygon) so it doesn't provide the result I need.
Thanks though!
Any other suggestion?
DuncanHornby
